Is there a way to add stakeholders automatically for only HIGH priority incidents?
So I’ve figured out that I can create response plays and add them onto our service settings but it appears that this will trigger regardless of incident priority.
For example if I open a p3 ticket it will automatically add and notify my stakeholders response play. This will send them a text message says ā€˜incident 00000 was created’. Typically we only need to notify our stakeholders for high priority incidents that are affecting daily operations. P1 and P2 only.
Is there anyway I can do this?
Hi Justin
The automated response plays will trigger for everything. You might want to try a response play that can be run on-demand by your responders that they’ll click on when the incident requires additional stakeholders to be notified.
You could call the response play ā€œNotify P1/P2 Stakeholdersā€ or similar, and allow all users to run the play on demand. Then folks can select the response play from the dropdown in the incident UI when they have a P1 or P2 incident. This would be helpful if an incident is initially assigned a lower priority but needs to be escalated as well.
We have a number of these types of response plays for managing incidents. Since they aren’t attached or limited to a particular service, anyone responding to an incident can run plays that do things like notify all engineering leadership or page an incident commander.
–mandi
